I'm after some help with voicemail.
I have managed to record my greeting but I cannot seem to turn on the voicemail
Following the manual I press the envelope button
Then voice messaging
Then it says to input voice box - does abyone know what this is?
Hi gwynjones,
I have had a look through the versatility handbook and it states to use Voicemail you need to have a " Voicemail Module to be installed" do you have one installed in your versatility system?
Markp
