Hi guys, im trying to block facebook from the network using a time schedule system on the router, the newer version of the firmware has content screening tools which is what I need. My version of the current firmware for the BT2700HGV router is 5.29.107.12 and the bt logo is in the left hand corner of the screen.
I called through to bt and after a 20 minute wait gave up as I was clogging up the business line being on hold for so long.
Can you please point me to a download link so I can do a manual upgrade via the tech/upgrade page once logged into the router.
thanx
Diego
Solved! Go to Solution.
Hi Diego,
Sorry for the problems you have been experiencing
Unfortunately we do not offer a download link for the firmware where you can run through the tech/upgrade option.
We can 'push' the latest firmware to your router - If you can send me a Private Message of your Router's Serial Number (Which can be obtained from routers GUI screen normally accessed on 192.168.1.254 then click on Settings > Summary) I will be able to get this arranged for you
Hi Diego,
It's possible that this router may not be upgradable as version 5 routers need to be on a specific firmware before they can be pushed to version 6, I believe it needs to end in 117.6 to be upgradable. E-Overtime will be able to confirm when he gets the serial from yourself.
