Backup Never Finishes If Over 3 Minutes
orthohin
Grand Master
Hello,
I am using a backup script from RevivedWire.com. The script seems to work great and the error I am getting has to do with PHP execution time or something (I am just guessing since I know absolutely nothing). Both IE 9 and Firefox 11 get the following message after only 3 minutes of execution of the backup.
The connection was reset
The connection to the server was reset while the page was loading.
I have increased the max_execution_time to 15000 but that did not seem to help.
Any help is greatly appreciated.
Thank you,
_______
Orthohin
1 REPLY 1
Sogo7
Grand Master
Unless you have your own dedicated or Virtual Private Server you cannot overide the max_execution_time. This is a safety feature to stop one website consuming to much CPU & Memory resources and  crashing everybody elses on the shared hosting server.
Sounds like you will have to make the backup in smaller chunks, does the script have a Cron Job option?
Lovelogic.net UK Jobs Scanner
