Started to use website builder pro 7.4. But the problem is that, we need to put a banner onto the front page, where do we insert the code, and we do have a space for it, we have done this a few times but with no luck, we are not web geeks by any means, so all the help would be very helpfull, so we could move on untill the next problem arises.
Many Thanks
Pete
Hello Pete,
You can add a banner in the "edit text" from the shop in the same way you add an imagine. The format must be swf.
If you want to put a banner in the home page;
->Content/Categories->Datasheet view->General->Edit tex (long desceription)->Edit text->Insert file->Upload file.
Kind Regards,
