Business Hub 5 at home
Awood22
Member
Hello
I have a Business Hub 5 and I wanted to know whether I would be able to use it on my home network. I understand that the main difference to the home hub is to do with the business hub using a static ip address whereas at home I dont have this - would I need to change any settings etc? thanks
1 REPLY 1
markp
Grand Guru
Hi Awood22,
With the business hub 5 you would need to change the login detiails that are in the Hub5 form your business details to your homw broadband details, other than this it will work on your home connection.
Markp
