Business broadband on ipad help! doesn't recognise my password.
pinkangel1241
Member
I have just changed to business broadband and cannot connect to my business hub 271 with ipad kepps telling me password is not recognisable, can anyone help? thanks Pinkangel1241
1 REPLY 1
MHC
Guru
Have you set up the same level of encryption on both?    Are you using exactly the same key?
Start from the beginning.   Turn encryption OFF and try connecting.   When you have that working, move to first level WEP,  ensure that works, then go to WPA ...
