Can screen size effect the way a web site displays?
Penman
Member
Hi,
I've checked my website on various computers and notice that it displays differently on different screens. On my screen it's normal, but on a different sized screen the site only takes up 1/2 or 2/3rds of the screen, and the rest is white.
Is this normal?
My site is via bt web hosting, and is called pencase.co.uk
My background picture on each page is one that I've put on, then placed photos on top - might this be the reason?
Would I be better just using a white background?
I hope someone can offer some help.
Thanks.
2 REPLIES 2
Cantoris
Power User
Yes, that is normal.
Some web designers suggest confining yourself to a page size of 800 x 600 pixels (px) and aligning your page centrally.
It is possible to define a page size so that it expands with the window. You would define the width not in terms of pixels but as a percentage of the window width. By default, EasySiteWizard defines by pixels. I don't know whether this can be overridden.
   Nigel.
Sogo7
Grand Master
To see how others see your site visit BrowserShots.org it's a completely free service and takes about twenty minutes to check your site against over one hundred different web browsers.
Had a look at the source code... it's not pretty in there.
Did you make any alterations to the page HTML by hand or just use the "EasySiteWizard" ?
Lovelogic.net UK Jobs Scanner
