I feel embarassed that this isn't obvious to me, but how do I change the font size and colour used to display the product price? I'm reasonably happy with the rest of my product layout, for the time being at least, but I would like my product prices to stand out a bit more.
Peter_G
Solved! Go to Solution.
Hi Peter
As with many things about the ePages software, some things are not so obvious. Go to Design > Advanced Design. Select the central part of your website so it has a red square around it. Then select "Prices & Product Views" from drop-down menu in Previews tab. To the right of this you should then see a new tab where you can edit font size, colour, etc.
Hi Peter
Thank you once again, Graeme.
I presume I must have stumbled down that path at some time in the past, but I couldn't recreate the journey before getting your directions. Then, having got to the right place, I found the editing process somewhat less than intuitive, but with some trial and error, I managed to achieve the changes I was after.
Incidentally, when I first tried your instructions I didn't get the red border around the selected centre box and this confused me for a while. It seems that I had de-selected the 'Editing help' function in the top left 'File' box on the 'Advanced design' page. Other than switching the red border on and off I can't see what else this function does.
Regards
Peter_G
