Connecting Android Devices
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi,
I am using the 2wire BT business hub (with latest firmware), and trying to connect two Android devices (Xoom 2 ME tablet on Honeycomb 3.2 and a HTC Desire C on ICS 4.0) to my home wireless network. Both of the devices have been used previously on a number of different wi-fi connections and worked fine, and my wireless works fine on a number of laptops.
Both devices pick up the wi-fi, but neither will make any type of connection with it. When I try to connect, it either does nothing or says "connecting" briefly before saying "disconnecting" and stopping. I have reset everything involved, tried all the wireless encryptions (none, wep, wpa, wpa2), tried different wireless channels, none of which made any difference.
I'm certain it's a problem with the router, but BT won't help as the devices are not laptops running on windows.
PLEASE HELP!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Don't worry. Disabled MAC filtering and all is good. Any idea why?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
because mac filtering will only allow certain mac addresses to connect. if you want to enable it you have to whitelist each device you want to allow to connect.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I agree. Each device will connect directly, so you need to like list them one by one if you don't want to have problems connecting each mobile device.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Can its work with mobile-phone-tracker.org mobile recorder on Android?
