- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello,
I've been noticing this error message come up for one of our clients in their Outlook profile. I gave them a new a profile and thought it would go away but it kept coming back. The only place it seems to be is in the "Sent" folder.
Has anyone seen anything like this and know how I can fix it?
Corrupt Message detected.
Fid = b-8D58735 ; Mid = 1b-BA7301E04B ;
Some or all properties of this message will not be transferred correctly.
Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
As last instance that might assist you try Outlook Repair Toolbox its demo version is here https://www.repairtoolbox.com/outlookrepair.html
Let’s try some steps:
- Open outlook in safe mode, and try to reproduce issue Run->Outlook /safe>
Notes: It’ll disable most of Add-ins to test if the issue is cause by them
- Please try to clean up the form cache, we may receive the messages which form has been modified some times
- “Tools” menu->”Options”->”Other” tab->”Advanced Options”
- “Custom Forms”->Click “Manage Forms”->”Clear Cache”
- Restart Outlook for testing
- If above steps won’t work, try to rename the form cache file
- Quit outlook, search “frmcache.dat” file on the hard drive, and then rename it
- Start outlook to check issue
Notes: Form cache will be recreated when next time you use a custom form
- Please try to recreate the mail profile in case the profile corruption may be the cause
- Try to change the location of the PST.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
