Create Web Contact/Feedback Form
bonzaman
Member
Hi,
Please can you advise whether the eShop allows for the creation of web forms using html form fields such as text fields, check boxes, radio buttons etc to allow form data to be posted?
Ideally we would like to create a contact form for general enquiries or a feedback form.
Regards
KMC
1 REPLY 1
Fiona
Grand Guru
Hi
Currently the only way to create a contact form is using the standard ‘contact form page’, onto which you can enter a contact email address e.g. [email protected].
In future updates we hope to include more flexibility of the contact form page to include turning on/off fields and individual texts. Unfortunately at present there is not a release date for any Eshop software updates.
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
