Hi guys need urgent help i am the web designer of a user with BT and i am having trouble forwarding the following url
harleystreet-cosmetic.co.uk to http://drnurein.co.uk/HarleyStreetCosmetic/index.html
is there any i can fix this i have called and called and called and i just egt the run around
i am getting
You are trying to set a www record, when one already exists for this domain. This can cause issues with the domain resolving properly. None of the changes just submitted have been saved. If you need to change a www record please use Advanced Domain Manager.
thank you
Hi Mgenterprise,
I have removed the addtinal "locked" records from our side, you should now be able to forward your domain.
Any problems please contact us via the dns enquiry form at www.dnsforms.co.uk.
Kind Regards,
Ian - F -
