Does anyone know how to set up Incredimail after migration to Office 365 platform?
Solved! Go to Solution.
Yes it should just follow the instructions below
in the server tab
change the incoming and outgoing server
then apply authentication to the outgoing server
then go to the advanced tab
then enable ssl for both servers and change the port numbers
here are a full list of the settings
Incoming server
Server - pop.outlook.com
port – 995
connection type – ssl
ensure that this is authorised with the full email address and password including the domain [email protected]
outgoing
Server - smtp.outlook.com
port – 587
connection type – tls
make sure the outgoing server requires authentication and authenticate with the same details as the incoming server
Hi I have just looked this up for you
go to
tools > accounts > add new >"let me configure settings myself"
enter the following
name - yourname
email address - your full email address i.e.. [email protected]
click next
then enter the following
My incoming mail server type is POP3/POP
incoming mail server - pop.outlook.com
outgoing mail server - smtp.outlook.com
next
username - full email address i.e.. [email protected]
password - yourpassword
then click finish
now under tools > accounts
click on the email account you have just set up
under the servers tab click on my server requires authentication then make sure that this is using the same details as the incoming server
click on this server requires a secure connection for both the incoming and outgoing mail server
set the port numbers as follows
in - 995
out - 587
click OK
that should now work
Thank you for that, but will this work on my existing email adrresses just by changing port settings?
in the server tab
Incoming server
port – 995
outgoing
port – 587
Thanks, I will let you know how I get on.
Changed the settings as per the instructions and everything seems to be working OK.
brilliant thanks for the reply i will mark this as a solution have a nice day Knotty22
