Enabling ASP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Does anyone know how to activate ASP please?
According to the instructions it says :
Click on Site Builders and follow the links to Windows Services, then select the Programming language you would like to enable.
But first there is no Windows Services, so I tried webmaster tools and when you follow this link, all there appears to be there are a load of softward downloads and nowhere to select the Programming language.
I am getting very frustrated and desperate now so any help will be much appreciated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Martin
Once logged into the Web Site Center,
If you click, Site Builders,
Then Windows(TM) Services,
This gives you the Option to Enable ASP Content on your website (you will need an ASP File on your FTP space)
IF you don't have these options your Webhosting doesnt have ASP Support and you may need to upgrade the level of Webhosting you have
Plumly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Please have a look..
http://support.godaddy.com/help/article/6232/enabling-aspnet-40-on-your-windows-hosting-account
__________
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Some of your other posts suggest that you are using the eShop package. If so, this doesn't come with ASP so you won't have this option.
