I would like to know how to put spread sheet files on my web site for people to download if they wish, how can I do this, I use easysite wizard to run site, can anyone help please
Derek
Your best bet to do this would be either File Manager (in your control panel under "Web Site Management") or with an FTP client. If you place the spreadsheet files in your public folder they can be downloaded by creating a hyperlink to domain.co.uk/spreadsheetfilename.
Hope this helps.
Thanks I will give this a try
No need to use the File Manager as the Easysitewizard Pro now supports uploading files like this through the hyperlink function.
Just use the hyperlink button as normal, then on the box where you are meant to enter the link, change the dropdown to File and you will then be able to browse for the file. This will then be uploaded and attached to your hyperlink.
