I have a BT Business Hub (2700). I need to have all floor space in my premises covered by wifi. What range extenders are compatible with the Business Hub? I know that it doesn't have WDS, which is why I'm asking.
Also, is it possible to daisy chain the extenders? Like Hub -> Extender -> Extender -> Extender and so on?
I've seen the post on here already, suggesting to use another 2700 in a wired config. Due to the size of my premises, this would not be feasible. Is there any way to do it wirelessly?
Thanks in advance.
Hi. You can use any AP as a repeater. I'm not sure about extenders.
Try to check out this link too.
Routers have features where you can setup a connection on business type although every ISP have a system where you need to purchase if you have a lot of computers that needs to put connections on.
