Hi,
I'm trying to login to my BT account using Dreamweaver so I can place my html email signatures there. However, it won't let me log in? I have my website hosted by someone else so trying to use the free one that comes with BT business.
I'm set up as follows,
URL of site -
http://home.btconnect.com/rgbdigital/public/
ftp hostname -
ftphost.btconnect.com
folder -
http/home.btconnect.com/rgbdigital/public/
login
rgbdigital
password
Thanks.
What do you mean that you are using a free one? I don't quite get it.
Here is the procedure for ftp login using Dreamweaver.........
In order to connect FTP server using dreamweaver one need to perform below mentioned steps to configure it:
1. Start DreamWeaver, click on the Site menu, and select Define Sites or New Site.
2. Select your web site from the list and click New or it will display following window.
3. Type Website name & Click Next.
4. Select No or Yes to use server technology.
5. Choose option "Edit local copies on my machine, then upload to server when ready.
6. Select local folder from your PC.
7. Select FTP from "How do you connect to your remote server?" option.
8. Several fields will appear that need to be filled out with your account information.
9. Select web site from the Site dropdown list.
10. Click the Connect button. This will connect Dreamweaver to your server.
11. Next, select the files that you wish to upload in the window located on the right hand side of your screen. Click the blue arrow and your files will begin uploading to your server. Use the green arrow if you wish to download files from your server to your local computer.
That’s it!
____________________
