Does anybody know whether a "FastCGI" feature is available with the BT Advanced hosting option?
The supplied Perl environment contains the module "CGI::Fast" but it just crashes. Perhaps the Perl interpreter has not been linked with the appropriate library and/or the required Apache module is not configured. How can I tell?
This is another case where there appears to be absolutely no documentation provided by BT!
Many thanks,
It looks like you're right, I would think that module would work but I've never tried it myself. I would probably suggest checking with support perhaps it is not configured properly on your account. Has anyone else tried it and found it working? I would but I don't do much with Perl that a little too advanced for me.
Either way I would say check with BT support and they can probably get it working for you.
