Can anybody tell me if its OK to use a voip line as a fax facility? Is there any software that I may need?
Thanks in anticipation.
There is no reason why it cannot be used. You may occasionally find that some pairs of machines which trained at high speeds (33k6) might drop down a little. Just ensure that you select the highest possible quality on the VOIP set up.
