Featureline Phone Mk II (or Mk 2) lead to phone socket
neilcharrington
Member
I bought a Featureline Mk 2 phone on eBay but it came without a phone lead.  I have about 30 leads that "fit" and non of them worked.  I have another Featureline phone that is working and tried the lead from that in the new phone and it worked.  I tried some of the other "standard" phone leads also in the existing phone but it didn't work either.  I have come to the conclusion that the Featureline Mk 2 phone has a special lead to connect to the featureline wall socket.  Has anyone found the same or can suggest a solution?  The seller sent a lead that also didn't work.  I will have to return it as not working unless I can find a lead that will work.
0 REPLIES 0
