Flushing BT HGV200 DNS Cache
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
It's not a big issue, but how do you flush or reset the router's DNS cache?
My router shows (via Settings/Broadband/DNS Resolution) several names with the same IP address, which has been picked up from the DHCP server, at different times.
flushdns from Windows, just flushes the Windows cache. There is no Telnet access on the router, so there doesn't seem to be a way to tell it to flush its cache.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
Sorry for the delay in responding to the post. I spoke to the technical team who said that the only was to clear the DNS cache is to clear the device list in the router:
In the router go to Settings -> Diagnostics -> reset them by clicking on the clear device list.
If this does not work you would need to factory reset the router.
I hope this helps,
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
