Hi All. I'm having a problem with the generic formmail script and hope someone can help as I'm esting the site before going live soon.
I've installed it using the site builder and copied all the code into my contact.html page but when the submit button is pressed on line we get this:
Method Not AllowedThe requested method POST is not allowed for the URL /contact2.html.
Also, when trying to looking at the server files I get this:
Starting download of /cgi-bin/formmail
Command: PASV
Response: 227 Entering Passive Mode (209,235,144,9,251,75)
Command: RETR formmail
Response: 550 formmail: No such file or directory
Error: Critical error
I had a brief conversation with telephone support and was told that the page has to be php. So I've also tried this option and this online creates an error message looking for ftp account authentication (username and password).
I'm new to all this so must be missing something basic. Some more info - using the starter £5/month option and dreamweaver for my design. Thanks in advance for any help.
John
Solved! Go to Solution.
The first line seems to be wrong as you have the form tag twice.
Try changing it to:
<form action="/cgi-bin/formmail" method="post" name="contactform">
Other than that it seems OK.
Firstly this is nonsense....
Command: PASV
You will get this because the formmail script is not actually copied into your webspace. Instead it is a symbolic link to the script elsewhere on the server.
Can you please post the form code that you are using (or a link to the page) and also the contents of the /private/formmail.conf file and I will see if I can figure it out.
Try changing it to:
