Frame forwarding and favicon
bad_coder
Member
Hi
Quick question: I am using frame forwarding at http://www.note-media.com/ and want it to pick up the favicon at the original site http://home.btconnect.com/notemedia/
I have added the following code to the original site
<link rel="shortcut icon" href="http://home.btconnect.com/notemedia/favicon.ico" >
so I guess I'd need to insert the same code at the framed pages, but how can I edit that code? Is it possible, or is it justgenetared by the BT site and cannot be editied? Or is there another way of achieving my aim?
Thanks. bad_coder
1 ACCEPTED SOLUTION
Accepted Solutions
dave
Guru
Not sure it is possible as there is no way to edit the code within the frame. You are not given any access to the frame.
In my opinion, frame forwarding is a poor way to do things as search engines only see the frame and not the content of the site.
View solution in original post
1 REPLY 1
dave
Guru
