General questions about web host management, WordPress and changing NameServers
robcub3
Member
I am redesigning a website for a client who is using BTBusiness for their domain name registration, web hosting and bespoke email.
They have given me just their email address xxx@btconnect.com and password and with that I can go into BT Website Centre however I don't seem to be able to FTP with an FTP client. The File Manager in Website Management is ... kind of basic!
I would like to install WordPress and, as I can see this is possible from another thread here, it seems unadvisable to me as I can't see MySQL database set up or PHPMyAdmin.
I see you're running PHP but do you have the mod_rewrite module running?
So, more importantly, how can you change the NameServers so that they point to another host (which can deal with WordPress better) whilst keeping the email management with BT?
Many thanks.
6 REPLIES 6
duskjome
BT Partner
BT Partner
Without the domain name I can only answer some of those questions. The user name and host name you would use to FTP are both your domain name. Your password should be the same one you use to login to the control panel. You can see if the package you are on has mysql database capabilities by checking in the control panel under Website Management for a Database Manager. This will allow you to create a database or get the connection settings for an existing database. Also you can set up a mod_rewrite in an .htaccess file if you need one.
robcub3
Member
Thank you, duskjome, the domain name is delmamss dot co.uk - I still can't login with a FTP client using that as the server and username but not to worry.
Under website management I have only
» Site Promoter
» File Manager
» PHP Manager
» Site Checker
I have also heard back from support saying that they would need to upgrade to the Advanced Hosting at £15 per month for this option.
So I would like to know where I change the NameServers for the domain name but keeping the email with BT.
In the same email from Support he says
"With regards to changing the nameservers, this can be done but the new host would need to set the MX record to ibmr.btconnect.com in order to keep using the BT email system. If you want to do this, please submit the support form 'titled DNS name server repoint'"
Where do I get this form?
James
Master User
Hi robcub3, go to Contact us and click on Domains & hosting. You will then see a link to the form you are looking for.
Cheers,
James
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
Thank you.
robcub3
Member
Thanks, James.
ffd
Member
Hi there
The link to Contact us returns a 404. Is there a newer link?
Thanks.
Alun
Master User
Link in the post has been updated. Smiley Happy
Regards,
Alun
BT Business Support Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
