Google lists my eshop as eshop.abizzfashion.co.uk and not www.abizzfashion.co.uk any ideas on how to fix it??
Hi, I had the same thing the answer is below - I went for it and now we index correctly - thing was we had to climb back up the searches as everything basically disappears or a 404 error is seen which is rubbish but is what you have to do.
"the reason that your eShop shows as eshop.*****.co.uk is that any eShop registered on our system is setup like this is some hosting packages have been configured so there is both a standard website and an eShop with the standard website on the 'www' DNS record(e.g. www.yourdomain.com) and the eShop on the 'eshop' DNS record (e.g. eshop.yourdomain.com).
I'm more than happy to change this so your eShop is primarily based on www.malkins.co.uk, the only issue with this is that in doing an existing links to eshop.*****.co.uk (including those in Google) would no longer work until your site was checked again. Unfortunately because we use the eshop DNS record to allow access into the admin section of the eShop I can't set this up so that eshop.malkins.co.uk redirects to www.*****.co.uk.
