Help! How do I align text within a text box?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
Never set a website up before and would like to know how to align text within a text box.
For example
Option 1 kdfdsfsdfdsfsjflksjdflk £5.00
Option 2 slkdjflkdsjfsdfdsfsdfsf £6.00
I can't seem to tab within a text box and if I try to just use the space bar, the columns are slightly misaligned.
Thanks!
0
Kudos
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This will depend on the editor you are using. If you are using Easy Site Wizard pro you would probably be better served using the "add a table" rather than the "add a texbox" feature. On other editors I can't really be sure.
