Help Required: using the staic Ip with the DHCP
ameyak
Member
We have a server on which SBS 2011 is installed. I have installed the DHCP role and configured the DHCP on the server. The following are the details of the server
 IP address : 192.168.100.65
 Subnet: 255.255.255.0
 Gateway: 192.168.100.1
DNS server : 192.168.100.1
This server is connected to the BT Hub 3 router. But the problem is i found that Public Ip of the server changes frequently. this IP is configured in  BT HUb router at
Settings --> Broadband --> TCP/IP Settings--> IP Adresss
Now we have purchased 5 static Ips out of which one I want to configure on this server. So that I can have the fixed Public IP. I dont want to change the DHCP Settings on the server. How to achieve this??.
When i configure one of the the static ip for the server in the settings --> Business Network. The internal Ip address gets replaced.
I tick mark both options while configuring static Ip
a) Use public fixed ip address
b) Always use this Ip address
And when i again manually enter my internal DHCP address, it again takes the public Ip from
And my server is not visible in the Business Network.
How can i configure the static Ip on the router????
Please Help!!!
0 REPLIES 0
