Hosting questions technical
Sogo7
Grand Master
Considering moving one or more  of my web sites to BT hosting but require some technical details in order to decide.
1> Is the cURL option "followloaction" enabled ?
2> Is the PHP command "file_get_contents" or similiar permitted to query an external URL ?
3> What are the limits for server resource useage and penalties for exceeding them?
4> Can CRON jobs be scheduled from the control panel
Lovelogic.net UK Jobs Scanner
2 REPLIES 2
Nguitar
BT Partner
BT Partner
-This would need to be tested
-This depends on your hosting package.
-No
If you have any further questions do not hesitate to ask
Sogo7
Grand Master
Am deeply concerned that it appears nobody here can answer basic questions relating to the hosting server configuration, this is not encouraging news.
