Hi Guys, we have had the BTepages store for quite a while and have a problem that has most likely been asked many times....
our web address is www.discotechnology.com but is displayed as http://www.btowstore.com/epages/Store2_Shop1973.sf/en_GB/?ObjectPath=/Shops/Store2.Shop1973/Categori...
How do we change this so our customers know who their looking at in search engines....?
Many thanks if anyone can help.
Richard
Hi Richard,
You will need to do 2 things here to make this work:
1. Contact your domain host and get them to remove the forwarding on the domain and instead set up the following DNS record:
www CNAME bt.epages.com
2. You will then need to raise a support request to BT asking us to change the address on the shop to www.discotechnology.com. Please select the domains and hosting option from the following page to request this:
