- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi,
I have two ADSL connections on two different telephone lines, one with a BT Home Hub and the other with a BT Business Hub Model 2701HGV-C. There are different devices connected to each hub and both are working OK as separate LAN’s. What I want to do is create one network with both Hubs connected. Hence I want to reconfigure the 2701HGV-C router gateway IP address (currently 192.168.1.254) to 192.168.1.253 so it doesn’t clash with the Home Hub gateway address. Can anyone help me with how to do this please? Or is it not possible to configure the 2 Wire 2701HGV-C router default gateway IP address?
Regards
smcoxon
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've answered my own question just after making thread - Doh!
For anyone else looking to do the same... Go to LAN > Private Network settings and then set up the 'Configure Manually' options under DHCP Network Range.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
