Hi, got Fibre installed last week. BT Hub 5 works ok, but limited range. Previously i had a Draytek Vigor 2820n with aDraytek extender upstairs. That was great. So, can i piggyback my Draytek system of the Hub 5so i can use the old wifi system and SSD, but with the highr speeds?
Thanks,
Mike
I have a similar setup with my cisco e4200,i just turned off DHCP etc on the cisco,set the ap name and passkey the same as the BT router and wired into the ethernet port.
