Hub BT2700HGV - Losing Settings - Widespread Problem?
fifex
Member
Hi
I joined this forum to see if others were having the same issue as me and hopefully get a response via the forum from BT as phoning customer support is totally pointless.
Who else has experienced the router losing settings and resetting to the factory defaults ?
There are a number of posts in here already but if we can get them all in one thread maybe BT will respond!
Paul
12 REPLIES 12
fifex
Member
Hi Mark
Thanks for the quick reply.
Can they give any specifics ? are there any makes/models that they know do/don't work? or are there any specs that I should be looking for?
Cheers
Paul
markp
Grand Guru
 Hi Paul,
They are not able to advise which ones will/will not work I am afraid, perhaps there are other cusotmers on the forum that might be able to advise what ones they have tried/used.
Regards
markp
fifex
Member
Hi Mark
Ok thanks for that I'll posty a question in the VOIP forum.
Cheers
Paul
