IP Profile set low on New connection
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
I posted this over on the Community Forums, but as this was a business line they have asked me to post here.
We have had a new ADSL line installed, and after waiting the initial 10 Days our connection profile appears to be stuck very low, although our attainable rates are good and noise margin is through the roof. These are the stats from our router (its a Cisco, but it does the same with the BT hub). I have called BT support but they insisted nothing was wrong and that there was nothing they could do
Modem Status: TC Sync (Showtime!)
DSL Config Mode: AUTO
Trained Mode: G.992.1 (ADSL) Annex A
DS Channel1 DS Channel0 US Channel1 US Channel0
Speed (kbps): 0 1152 0 288
Attainable Rate: 0 10968 0 1204
Line Attenuation: 30.5 dB 16.5 dB
Signal Attenuation: 30.5 dB 0.0 dB
Noise Margin: 48.2 dB 28.0 dB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
It does look like you have a line fault. Did the helpdesk ask you to go into the test socket?
Have you also checked to see if your line is capable of the speeds you expect?
You can check here - https://www.samknows.com/broadband/broadband_checker
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi dlwood,
Can you send me a private message with your contact details and the phone number of the line and I will get the helpdesk to have another look at the line for you.
Markp
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks Mark. PM sent
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Spank
The line itself looks healthy as the attainable rate is good, and there are no errors to speak of. The issue appears to be the profile the line is stuck on.
Interesting thing is that evertime we try do a "further diagnostics" test on the BTW Performnace Test (http://speedtest.btwholesale.com/) which will normally tell you what IP profile your line is on we get the following error:
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks to anyone that assisted, our speed shot up last night to this:
Speed (kbps): 0 8128 0 832
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi dlwood,
that is good news, your profile was not incorrect. What the issue was, is that your line was capped at 1Mb, I was able to get a order put through to remove the cap for you.
Markp
