IPv6 on Business Broadband
Stoogieb
Member
Hi,
I have both a Consumer and Business line coming into one router. The Consumber line is running into the routers VDSL port.
The Business is BT Business Broadband fibre, with a PPPoE connection from the BT Business Hub 5 into the routers WAN Port, using PPPoE, and works fine with IPv4 and the static IPs allocated.
The consumer line has automatically connected to IPv6, and is working fine.
The Business Broadband over WAN / PPPoE is showing IPv6 packets being recieved, but it is not connecting.
What should I expect from the business line?
Thanks!
1 REPLY 1
markp
Grand Guru
Hi Stoogieb,
With Business broadband we have not rolled out IPV6, it is still being trialled.  When have no date as of yet to when it will be getting rolled out accross business connections.
Markp
