The max speed we have ever been able to achieve is about 3Mb although the Hub shows about 5Mb.
I have just run http://speedtest.btwholesale.com/ and the speed showed 1.4Mbps and then rerun 3.5Mbps ping 66ms.
Our server is running Windows Server 2011
Can anyone suggest anyway I can monitor what may be causing the problem and also comment on the data below. In Particular the Corrected and Uncorrect block counts - do these indixcate anything. This is data collected over a bit more than 24 hours.
DSL Details
| Modem Type: | Built in modem - ADSL | |
| DSL Line (Wire Pair): | Line 1 (inner pair) | |
| Current DSL Connection: | ||
| Rate: | Down 5971 kbs | Up 917 kbs |
| Max Rate: | 5889 kbs | 912 kbs |
| Noise Margin: | 8.7 dB | 5.5 dB |
| Attenuation: | 46.7 dB | 25.7 dB |
| Output Power: | 19.5 dBm | 12.5 dBm |
| Protocol: | G.DMT2 Annex A | |
| Channel: | Interleaved | |
| DSLAM Vendor Information | Country: {46336} Vendor: {IFTN} Specific: {51313 } | |
| ATM PVC: | 0/38 | |
| Rate Cap: | 5889 kbs | |
| Attenuation @ 300kHz: | 46.7 dB | |
| Uncanceled Echo: | -11.7 dB | Ok |
| VCXO Frequency Offset: | 6.0 ppm | Ok |
| Final Receive Gain: | 25.5 dB | Ok |
| Excessive Impulse Noise: | 0 | Ok |
Traffic Statistics
| IP Traffic | Bytes Packets Errors %||||
| Transmit: | 1012255532 | 83 | 0 | 0 |
| Receive: | 3164942025 | 4058410 | 0 | 0 |
| ATM Traffic | Cells Errors %||||
| Transmit: | 29121401 | 0 | 0 | |
| Receive: | 69498414 | 0 | 0 |
DSL Link Errors
Collected for 1Day22:53:28
| Since | Current | Current | Time Since | |
| Reset 24-hr int. 15-min int. Last Event | ||||
| ATM | ||||
| Last Event | ||||
| Cell Header Errors | 8937 | 8083 | 8 | 0:00:15 |
| Loss of cell Delineation | 799 | 685 | 2 | 0:00:48 |
| DSL | ||||
| Link Retrains: | 0 | 0 | 0 | 0:00:00 |
| DSL Training Errors: | 0 | 0 | 0 | 0:00:00 |
| Training Timeouts: | 0 | 0 | 0 | 0:00:00 |
| Loss of Framing Failures: | 0 | 0 | 0 | 0:00:00 |
| Loss of Signal Failures: | 0 | 0 | 0 | 0:00:00 |
| Loss of Power Failures: | 0 | 0 | 0 | 0:00:00 |
| Loss of Margin Failures: | 0 | 0 | 0 | 0:00:00 |
| **bleep**. Seconds w/Errors: | 3080 | 2465 | 8 | 0:00:15 |
| **bleep**. Sec. w/Severe Errors: | 101 | 101 | 0 | 7:15:55 |
| Corrected Blocks: | 485214 | 432973 | 734 | 0:00:05 |
| Uncorrectable Blocks: | 10273 | 9344 | 10 | 0:00:15 |
| DSL Unavailable Seconds: | 0 | 0 | 0 | 0:00:00 |
Hi there Datum,
Can you tell me what happens when you let a page load and then press [ctrl]+[F5] ?
Can you also tell me what your ping time is please?
You can get this by running a speed test, however the best way to do this is through the Command Prompt/ terminal
IN Windows
In Mac
It is also worth while pinging the IP address of google .co.uk to see if your DNS server is at issue, as soon as you ping google your computer and show you this. Its then just a case of replacing www.google.co.uk with the IP.
An example of this would be
--- PING www.google.co.uk (74.125.143.94) 56(84) bytes of data. ---
64 bytes from 74.125.143.94: icmp_seq=1 ttl=46 time=41.7 ms
Then just substitute 74.125.143.94
If you are noticing a high ping time to google but not to the default gateway/router contact us
If you are noticing a high ping time to both then there is an issue in your internal network
If the router/default gateway is ok, the IP is ok, but the web address is high then we have an issue with the DNS server and need to change that.
Its also worth while clearing any and al proxy settings in your browser.
I hope this helps
Burkem5
