JoomForce( 1.5 , 1.6 & 1.7 Native )
JoomForce is a Joomla and SalesForce CRM integration component. Now Lead or Contact capturing is made so simple, You just need to click the Synchronize button in Joomla to get all your SalesForce Leads or Contact Fields into your website and the form is populated automatically. Thats all it needed to integrate your SalesForce CRM fields into your Joomla. Whatever the data or form filled up by customers in your website are directly inserted into SalesForce CRM.
Features of JoomForce ( 1.5 , 1.6 & 1.7 Native )
Front end Features List:
- Lead Form - Lead capturing from the website to SalesForce CRM is made possible using this lead form that can be enabled in the front end. The leads submitted using this form in your website will be automatically updated in your SalesForce CRM leads module.
- Contact Form - Contact capturing from the website to SalesForce CRM is made possible using this contact form that can be enabled in the front end. The contacts submitted using this form in your website will be automatically updated in your SalesForce CRM contact module.
- Dynamic Display - Form Field Label, Size, Order display all can be modified from the backend and displayed dynamically in the frontend.
- Form Validation - Form validation is done automatically according to the field created.
- Captcha Security - Form submission is made secured using captcha security image in the form. Considering user's captha usage we have made the option to show or hide the captcha in the form using the backend setting. So that you can either show it or hide it in your form as per your wish.
Back end Features List:
- Global Settings - This is the area that we have provided for the administrator's to add the crm details and other settings, thus making the SalesForce CRM integration process very easy and simple. Front end settings like captcha settings and others will configure here.
- Leads Fields Page - This is the area where you can have your lead form fields listed.
- Contact Fields Page - This is the area where you can have your contact form fields listed.
- Synchronization - Now having your SalesForce CRM leads and contact fields in your joomla website is very easy that you can obtained it by just pressing the Synchronize Crm Fields button provided in Lead page, then all your SalesForce CRM lead fields will be listed in your joomla.
- Field Edit - This feature helps you to modify the field label, field size, make the fields required or not.
- Field Ordering - You can reorder the fields ordering in the form using the order option.
- Preview - You can check how your form will be displayed in the front end from your backend itself using the Preview option provided.
Multi-Language-Support:
Now you could have your Lead or Contact form in any language. JoomForce supports Multi Language, it is integrated with your JoomFish Component.
Lead Capturing:
Lead capturing from the website to SalesForce CRM is made possible using the lead form that can be enabled in the front end. The leads submitted using this form in your website will be automatically updated in your SalesForce CRM leads module
Contact Capturing:
Contact capturing from the website to SalesForce CRM is made possible using the contact form that can be enabled in the front end. The contacts submitted using this form in your website will be automatically updated in your SalesForce CRM contact module.
This is the best Joomla salesforce integration and to get Slesforce joomla integration system please visit us at http://www.jextn.com/joomla-salesforce-integration-extension-download
