Joomla SEO Settings Conflict
tviljoen
Member
We have found that switching on the Search Engine Friendly URLs option in Joomlas' SEO Settings disable the menus in the site. When we disable the option, the menus work again. Has anyone perhaps foound a workaround for this problem?
1 REPLY 1
Tracey
Guru
Hi tviljoen,
Joomla is a third party application and unfortunately we do not support such applications. In order to resolve your request we kindly ask you to contact Joomla technical support department.
Kind regards
Tracey
BT Forum Moderator
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
