- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi,
Looking for some guidance regarding Easy Wizard Pro.
Firstly I can't get the google map to function. Although I use the widget and complete all the guidelines, once the site has been published and you try to access the map it always displays error message. The manual makes it sound simple enough, so what am I needing to do?
Secondly, I need to have links on my web. For example to get listed with a search engine such as bookkeepingfinder.co.uk I need to have a link and copy/paste html onto my web. I've tried and failed. Can't find info within the manual. Can anyone help? I am not exactly brilliant with these things so please "spell it out".
Many thanks
Derek
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
With regards to the map, can you either post the error or a link to the page so we can take a look at it?
FOr copying and pasting HTML, you need to click the Pencil icon then select Edit HTML Source. You can then paste your HTML in there. However, please be aware that this will directly affect the way your page displays so you can't just stick it in anywhere.
Possibly adding it at the end may be the best idea.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
