MAC Filtering BT2700HGV
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
(PDF file )
http://business.bt.com/pdf/BT_Business_Hub_tech_spec.pdf
mac address filtering takes place on wireless clients too. If it is not , could be a firmware issue . Try a factory reset .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
example - you are connecting 3 pcs (wr1 ,wr2 wrn)by wire to the router and about 5 by wireless(W1,W2,Wn) , mac address filtering in some routers can only restrict the wired pcs and some like Linksys filter MAC address on the wirless pcs (W1,W2,Wn) only.
Yet other brands like belkin applies mac address filter to all pcs irrespective whether they are connected by wire or wirless.
Now as far as official documentation is concerned , 2700 MAC filter restricts the PCs connected wirelessly. If it is not doing so ; chances are that it needs a factory reset or we are missing some hitherto unknown setting ...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
an online support form is also available.
Contact BT Business
is there a way to back up your setting from the router ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello
we are experiencing the same issue, have you got a solution yet?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi All,
We had this looked into. On initial testing it appeared that Mac filtering didn't work, even though devices were showing as being blocked. Going to Settings> Diagnostics> Resets and reset the wireless back to default settings and then enabled Mac filtering again… this seemed to resolve the problem, any new devices that connected weren't able to authenticate and automatically added to the blocked list; moving the device to Allowed then allows that device to authenticate and get web access. It appears on factory reset, the router displayed the same behaviour, this again was resolved by accessing the Resets section of Diagnostics and resetting the wireless to factory default… from there Mac filtering worked as it should.
Hope this helps,
Alun
BT Business Support Forum Moderator
Alun
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
