I wanna not access one or two machine in my LAN getting internet but access LAN information. Is there any option in BT Business Hub that I can control internet access according MAC address?
________________
Orthohin ![]()
Solved! Go to Solution.
Hi orthohin,
Yes the Business hub, can restrict access devices via MAC code filtering. Is you go to How do I set up MAC address filtering this explains how to use this feature with the BT router.
Regards
Markp
BT Business Forum Moderator
Hi orthohin,
Regards
Markp
Thanks Markp!!!
I have check that one. Nice and easy to setup.
______________
