More than 2 Falcon phones on line
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
As far as I can see, only 2 Falcon phones are supported on 1 VOIP line. Is this correct?
Due to the size of the house (4 floors) I would like to have 3 extensions (all on the same number) to save having to run up and down stairs to answer a call.
If it is not possible to have more than 2 Falcons, is it possible to maybe have 2 Falcons and also a standard phone plugged into the phone socket of the BT Business Hub and if so would this be on the same number as the Falcons
Hope someone can help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hi Turnyt
Yes it is possible to configure the router to use the same line as the falcons.
To configure the router go to www.bt.com/businessbbv login with your 0560 number and password and follow the online instructions, when you get to the last step and it asks for a username and password they are:
UN:admin
PW:this is your routers password (by default it is the serial number of the router unless changed) this can be found above the barcode on the side of the router.
Hope this helps.
Regards
Sean
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
