Multiple servers and assigning multiple static IP address with BT Hub
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have spoken to BT's tec department over the last few months in relation to users that wish to have more than one web server running from the BT Business Hub. BT tec lads have been told this cannot be done. I have done this very easy and have published a book on how to do this and how to set up a home or office web server, (running multiple web servers from BT hubs.
BT tec departemnt said as soon as the book is published please post in in the forums, It wont get deleted as this is a great help to us, we are under the inpression it cannot be done and many of our customers are asking how to do this.
Even BT tec lads have said, omg its so simple why didnt we think of that.
The book is avaliable at Lulu and will also be on amazon and watersoons with the nexted 6 weeks.
Lulu book store <Link removed>
we are also publishing a website over the next few weeks for tec support relating to the book and its contents,
<Link removed>
The book covers a lot of issues that you will come accross. The guide in the book has been used to configure a bt hub to run 10 web servers each with a static IP address. Following the simple guide you can have multiple web servers setup and running with a few hours.
The book has lots of screen shots for you to follow.
Learn how to build a home or office web server. With an easy to follow guide you can ...... Configure your home network Assign static IP addresses Select and build hardware Build a virtual private server (VPS) Build a dedicated server Install CentOS from a DVD Rom Create a bootable USB pen drive Install CentOS from a USB pen drive Use open source software Install &configure software Install & configure cPanel Configure & install server security Assign Domain names to your server ...... Plus Much More
I could not publish each point that needs to be covered in these forums as this would be a few undred forum posts. If you have any questions or require help you can always PM me, Buy the book, or use are website to get help.
Mod note: No direct advertising please. Feel free to use PMs to send links if people want them, or they can contact you.
How to Build a Home or Office Web Server
http://www.buildawebserver.co.uk
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The book, How to Build a Home or Office Web Server has been specifically wrote using BT as the ISP (internet service provider), with BT's static IP address and broadband speed you can run web server, VPS or Dedicated web servers from your home or office and assign multiple static IP address to each web server.
Learn the secrets of setting up your own home network, configuring and building a home webserver. Don't get stuck trying to assign multiple IP addresses, in less than an hour with simple to follow illustrated guide you can configure your bt business hub and turn an old pc or laptop into a powerful server.
The book is Now available at the following outlets, plus many others, (ISBN 978-1291329575)
<links removed>
