Can anyone help please
Solved! Go to Solution.
Hi thanks for reply, you are correct, updating the software to give it a better look has created yet again more problems. I have had to change all links to all photoalbums on the website, thank you for your help.
This is the first time I am using Photo Album and what I have found is that even though I publish the photo album I cannot see it through the link on the website unless i publish the website again. I am thinking that you may need to publish in a certain order for the link to work.
Also, writing as someone that has had to create a new website, because the old website was not compatible with the new software, I think you may need to update your links to the new name. May I suggest that you change one of your links and if it works then sadly you will have to change them all.
It seems updating the software to create a better look and feel has only created unnecessary problems. Good luck.
