PC drivers for Versatility software
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello,
I have successfully managed to connect my laptop to the Versatility box on the wall, and have installed the software, only to find, probably because I am using Windows 7, that the software does not connect to the box, I suspect because when I plugged in the USB connection that I bought a message appeared saying that drivers were not installed successfully for this hardware. Does anyone have a solution for this? Any ideas will be helpful, as long as it's not 'install XP....'
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Are you using a serial to usb converter, if so from experience I know that some will work as a programming cable and others will not. The one that I use and have had no problems with is made by Bandridge, saying that, I use Windows XP.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hii
I have previously used a usb serial converter on my last laptop and it worked fine but now that i have a new laptop it doesnt seem to recognise it, I am using windows xp but it doesnt seem to connect to my versatility box on the wall, i have treied to update the drivers but this hasnt worked any other ideas, will e very much appreiciated.
thank youu
