Photo Album 2 - issues
Garro
Member
Hi I would be grateful for help. I have been running a photoalbum using photo album 2. This has been fine until recently after loading in more photos the album view has reverted to thumbnails only; i.e. I picked a display format with a single large image with the thumbnails arranged below. The slideshow then operates through the the large picture. The position of the large picture is the same however it remains to be thumbnail size? I have tried changing the template and creating a new album with no change.
Any help would be appreciated.
Thanks, Garro
1 ACCEPTED SOLUTION
Accepted Solutions
duskjome
BT Partner
BT Partner
That is being caused by the template change. If you use one of the templates that show thumbnails only with no large images  the slideshow should work as normal. The other templates, at present, only show thumbnail sized image. The larger box on top is to accommodate captions.
Hope this helps.
View solution in original post
3 REPLIES 3
duskjome
BT Partner
BT Partner
Hope this helps.
Garro
Member
Hi I have picked the thumbnail only template as suggested and the slide show is working ok, so many thanks.
Cheers, Garro
kerrywalker1988
Member
hi there, is this fault likely to be fixed or not? just wondering as would like to use the other templates...?
regards
kerrywalker1988
