Hi - any help appreciated.
I've set up a Photo Album on our site, and published it OK. After logging in again later to edit some text, while it remains online (without the edits), the the editor tells me there are no albums.
Do you get an error message when you try to create a new album?
Hi Dave - thanx for replying.
The behaviour's changed since my first posting. Now when I go to Photo Album, it returns a blank Photo Album 2 window showing no albums. Clicking Albums returns 'you have to select an album' , but there are none showing to select.
Previously, no albums were showing, but there was a Create New Album button.
Tony
OK, it's not the fault i was thinking of.
Can you try rebooting your router and see if that helps?
Another thing... are you using Internet Explorer 8? If so, click No if you get the security warning prompt
Dave - Thanks, problem seems sorted after rebooting my router. What was going on?
Incidentally, I'm on Mac OSX, although it was the same on several Win systems.
Tony
