Problem with VAT number when registering with eShop
Samprod
Member
Hi,
We have received loads of reports from customers that our registration page is faulty. When we investigate, it appears to be the VAT field that is causing problems. Although it is not set as a required field, when it is used, the number has to be entered in a certain format. If the format is incorrect, it tells the customer that the VAT number is invalid, but not that the format is wrong. Therefore, after many attempts at entering their VAT number without success, they call us to report that they are unable to complete registration due to a fault.
Can the field be changed to allow various formats (i.e. GB 123456789, GB 123 4567 89, etc.)?  Or, as this is not a required field, can the customer be allowed to complete registration even if the format is not correct?
Regards
4 REPLIES 4
eShopTeam
Master User
Dear Samprod,
thank you for contacting BT.
We have tried several different combinations of the VAT, but unfortunatly, we could not reproduce the error:
GB 123 4567 89
GB123456789
   GB123456789
GB 123456789
GB 123456 789
GB 123 456789
GB123 456789
We would advise you to edit the texts of the Basket Settings in order to inform the users about the correct format (GB 123 456 789). For doing this, please, go to the top menu under "Settings >> Basket settings". Now, in the "Texts" tab, in "Text for the top section of the shopping basket", you can introduce this information.
We hope this information helps you. May sou have any further questions, please, do not hesitate to contact us.
Yours faithfully,
The eShop Team
Samprod
Member
Thanks for your reply.
Just to clarify, the problem occurs on the registration page, not in the shopping basket. After re-checking I can confirm that I am still able replicate the problem customers are reporting.
We have checked the back office, but are unable to find where text can be added to the registration page?
Regards
eShopTeam
Master User
Dear Samprod,
we need your access data to the shop to go on working on this case. Could you please contact BT?
Thank you and regards,
The eShop Team
eShopTeam
Master User
Hello,
We have forwarded this as an improvement request to the developers. It has been added to a list for future improvements. In one of the next patches it will be available.
Best Regards,
The eShop Team
