Just finished updating my website www.AlcuinLanguages.com, which views nicely in IE8. However in Mozilla Firefox, the side menu bar (main navigation bar) on the website is compressed and the text overlies itself making the website pretty well unusable in MF! It was fine in MF before I did the update (I moved the menu bar slightly in the update, no idea where it was before I updated though). Can anyone help please?
Many thanks
Solved! Go to Solution.
That might be an issue with your monitor or desktop resolution settings. When I view it from my PC on IE and Firefox I'm seeing the same as BLWRAVE, the menu looks about the same in both browsers and is normal sized.
Hello
What i would advise is to update your site in the Firefox browser and then publish your site and this should fix your issue with firefox but check IE8 to verify that there are no issuses with the menu bar.
Thanks, I've tried this but it displays badly in Firefox even in editing mode.
Hello
I have checked your site using firefox and IE and there are small differences I see. What is the main issue with displaying badly? I have checked both and the only difference I see is font size.
When I view the site on Firefox, the menu bar at the side is very squashed up and is hard to click on.
Well, I'm delighted to hear that. Thanks.
