Hello,
I have a monthly feed from e-shop into Google Base which has been working fine until this month. I haven't made any changes but it has now fallen over and I'm not sure how to fix it.
It basically says there is a corrupted data feed line with two errors - We were unable to match the attributes in your items to the attributes in the header row, due to invalid encoding. Please verify that all the characters are valid for your selected encoding.
Has anyone else got this error or know how to fix it ?
Many thanks,
Regards,
Paula
Hi,
Is anyone else having the same problem ? Or anyone know how to fix this ?
BT - can you help ?
Regards,
Paula
Hello Paula,
Are you sure the settings in Google Base are correct:
1. File Format = Text
2. Encoding = UTF-8
3. Delimiter = Tab \t
4. Use Quoted Fields = Yes
Thanks, Orchie
