Publisher Form/New Website
hcfm
Member
Hi
i am a new user to bt and also have built my first website. i used microsoft publisher, managed to upload it (after 24 hour of working it out LOl) however i have a problem.
Page 3 consists of a contact us form and i have included the submit button, and in the form properties i have put the e-mail address i need the info sending to, but when the site is published i get an error when text is entered and submit is pressed.
Can anyone tell me what i need to do to get it to work? Its probably something that i need to amend or tick or something but i can't see anything obvious at the moment.
The site is www.warringtonfoothealth.co.uk
thanks in advance
andrew
1 REPLY 1
duskjome
BT Partner
BT Partner
This one is getting into coding so I can be sure. From what I've see though this usually results from trying to publish with the server extensions without installing them in the control panel. Try publishing with ftp protocol or install the server extensions and publish with those and see if either of these options work.
Hope this helps.
